ZOTAC has announced their new ZOTAC GAMING GeForce RTX 4070 Super Twin Edge GPU and the SFF world can be pleased that it’s a true 2-slot solution. Not 2.1 or 2.2. Truly 2-Slot.
Only 2-slot width. Thank you.
The Twin Edge 4070 Super features the a twin fan design that ZOTAC calls IceStorm 2.0. This includes a fan stop feature built-in to the stock cooling profile, metal backplate, and support for ZOTAC’s FireStorm utility that allows for overclocking, voltage control, RGB control, custom profiles, and custom fan settings.
The card height is listed as 123.5mm thanks to the shroud peeking upward a bit, however it is...
Continue reading...
