Thanks for the response Josh.
I mention GPU fan headers because of this
picture from this
post. lf fans for the GPU are hooked up to the motherboard is there going to be good real time temp sensor feedback? I imagine the card could get critically hot before the temperature sensor on the motherboard would pick up on it. Also, I've never seen the option to select a GPU temp sensor for a motherboard's fan curve.
The stock card will get used for awhile to see how noisy it really is before putting noctua fans in.
One more thing for you Josh, the noctua L9a AMD CPU cooler looks like it can't be orientated so the fins are parallel to a motherboard's ram. Noctua does make an adapter kit for the L9i so it'll work on AM4 sockets. Do you have to have experience with this? Is the adapter kit the better option?
I'm leaning that way. Thanks for your feedback.
