If I understand right the Z390 Phantom Gaming-ITX/ac allows to splitt the one PCIe slots with a Rise Cable to two or eventually even 3 PCIe connectors.
Wich means
16x -> 8x + 8x
or
16x -> 8x + 4x + 4x
Read in specs:
https://www.asrock.com/mb/Intel/Z390 Phantom Gaming-ITXac/index.de.asp#Specification
In the Mnaual in the BIOS Section it says even:
Riser Card Support:
-Riser Card:Enable x8/x8 to x8/x8
-Enable x8/x4/x4 to x8/x4/x4
-Disable to x16
http://asrock.pc.cdn.bitgravity.com/Manual/Z390 Phantom Gaming-ITXac.pdf
So from this I guess I am right.
If so where can I get a riser card like this?
Wich means
16x -> 8x + 8x
or
16x -> 8x + 4x + 4x
Read in specs:
Riser Card Support:
-Disable to x16
