Is Xilence A404T Is it good enough for? AMD Ryzen 5 1600X 3.6GHz?
Warranty - 24 months
Description - Widening the Performance C CPU cooler Series, Xilence now launches the A404T AMD – a compact but highperformance top-flow cooler for powerful multi-core processors. The cooler scores with a silent 92mm fan and an innovative fin design allowing an easier circulation of air through the reams of fins. Thus, the speed of the PWM-regulated 92mm fan can be kept at an especially low level. Thanks to the heat pipes being in direct contact to the CPU, the heat transition between CPU and cooler proves to be very smooth and efficient.
Vendor Homepage - www.xilence.de/en/products/cpu-cooler/amd-cpu-cooler/xc040.html
Unit Gross Weight kg - 0.366
Unit Net Weight kg - 0.306
Shipping box quantity - 1
Unit Brutto Volume cubm - 0.001352
Noise level, max dB - 21.8
Air flow cfm - 65.4
Dimensions - 105 x 100 x 55mm
Thermal resistance 125W
Socket - SAM2
Socket - SAM2+
Socket - SAM3
Socket - SFM1
Socket - SFM2
Socket - SFM2+
Socket - SAM4
- AMD SenseMI Technology
- AMD XFR (eXtended Frequency Range) Technology
- Socket AM4
- Max Turbo Frequency 4.0 GHz
- 16MB L3 Cache
- 3MB L2 Cache
- DDR4 Support
- Unlocked Processor
- Thermal Design Power 95W
- Without Fan and Cooler
- Silent hydro bearing 92 mm PWM fan
- Four 6mm copper heat pipes for a maximum heat dissipation
- Light aluminum heat sink
- Suitable for AMD sockets AM4/AM3/AM2/AM2+/FM2+/FM2/FM1
- Thermal paste included
Air flow cfm - 65.4
Socket - SAM2
Socket - SAM2+
Socket - SAM3
Socket - SFM1
Socket - SFM2
Socket - SFM2+
Socket - SAM4
