Power Supply Will a HDPLEX 400w DC-ATX module fit in a Logic Supply MC600?
protango
I'm new to all this so please go easy on me if this is a dumb question haha. Note: I'm talking about the DC-ATX module only, the AC-DC converter will be external.
I'm thinking about doing an SFF build in an MC600, however all the previous builds I've looked at in the MC600 seem to use the HDPLEX 200w DC-ATX module, nothing I can see uses the larger 400w module. I was wondering if this is because it wont fit in the case?
It's hard to tell just from the dimensions, but by my calculations it should *just* fit either on top of the mobo, or behind the GPU. Practically though I'm not sure if either of those positions would actually work due to cable clearances and such...
Any advice appreciated!
