Will a Deepcool Castle 240RGB V2 AIO fit in an Ncase M1 V6?
googer
Hi all!
Just got my M1 v6 and am building it around a Gigabyte b550i board and Ryzen 3900x, loving the build quality!
Would like to ask if anyone is using the Deepcool Castle 240 RGB V2?
I really want to get it to due to the reasonable price and anti-leak technology, however, I am concerned about fit due to the anti-leak tech that makes the radiator slightly longer at 283mm, whilst the usual suspects like NZXT Kraken X53 and Corsair H100i XT etc are around 275mm.
The pump is also taller than usual at 71mm.
The full dimensions are:
Pump Dimensions91×79×71 mm
Radiator Dimensions282×120×27 mm
Anybody with experience or advice?
Thanks in advance!
davirock
Hi all!
Thanks in advance!
Hi, I have a similar question... I'm close to buy a M1 v6.1 and I would like to install a deepcool Captain 240pro V2... And the question is the same, it is few millimeters longer than the other 240 AIO...
Did you buy the AIO you mentioned?
