I have the Noctua U9B SE2 (similar to U9S), and I'm about to secure the cooler to the motherboard, but not sure which orientation to place it. I have the two fans with my cooler and in my original ATX case I had them configured to push air through the cooler and out the back of the case.
However this case has top ventilation holes so I have an additional option.
1) Is it better to have it so the cooler fans exhaust out the back of the case?
https://1drv.ms/u/s!An6UczaZhdfhkp51cInYKkpHwUQRBw?e=xI7JG3
2) Or should I exhaust out the top of the case?
https://1drv.ms/u/s!An6UczaZhdfhkp56I7rqBBhYcQvA9g
Exhausting out the top has the additional benefit that the fans don't overlap with the ram, but instead one fan overlap partly over the M2 slot. When the cpu cooler is oriented so the fans exhaust out the back one of the fans sits on top of the RAM modules, not a big deal but just wanted to mention it in case its an issue for the RAM having a fan on top of it.
Also I have this additional 120mm fan (regular thickness) where is the best place to put this fan? (anywhere but bottom because of my video card thickness)
https://1drv.ms/u/s!An6UczaZhdfhkp556N25VpOGIe7n6Q
