What is this connector called?
Antioch
What is the name of this header and the female pins use in it? It's the same one used on PicoPSU, PicoBox, etc. I'm looking to buy replacements. Thanks.
Choidebu
1,039
1,004
JST-PH? Might wanna check online if dimensions are correct...
JST got shitton of plugs can't be bothered to remember them all.
Antioch
Close but not quite! Thanks for the suggestion though, will look into it.
