I plan on building in the upcoming Streacom DA2 watercooling to be specific with the following.
Ryzen 2700x with EK-Supremacy EVO - Copper Acetal CPU Waterblock
Vega Frontier Edition with EK-FC Radeon Vega - Acetal GPU Waterblock
EK-XTOP DDC PWM - Acetal feeding into a 100mm Reservoir
Alphacool NexXxoS ST30 Full Copper X-Flow 240mm radiator paired with Corsair ML120 Fans
However, I have read that both the 2700x and the Vega 64 can cook eggs and boil water respectively.
Below is one of the various configurations for this SFF case, and again I may be misinterpreting what I am seeing.
I am thinking where the proposed 2.5 drives are located, I can instead place the DDC & Reservoir.
I am a novice at watercooling, so I ask will this Radiator be enough to cool the aforementioned.
And will my configuration work? If not what do you suggest? The case ships mid August so I have a month to plan.
