Vent hole pattern?
wywywywy
272
219
Hi all,
I am thinking of drilling a bunch of ventilation holes on the side panel rather than making a window. But I of course want the new holes to match up the existing ones.
Does anyone have the specifics of the hole pattern?
It looks the diameter is 3mm, and the pattern is 45 degrees, 5mm pitch. Is this right?
Thanks.
