Just finished building my Velka 5
It was my first time building a SFF PC and it went better that i anticipated.
The actual building took me 45 mins.
Parts used:
M/B: MSI MPG Z390I GAMING EDGE AC Link
CPU: INTEL i5-9600KF Link
CPU COOLER: CRYORIG C7 Link
TIM: Thermal Grizzly Conductonaut Liquid Metal Link
RAM: CORSAIR VENGEANCE LPX 16GB (2 x 8GB) DDR4 DRAM 3000MHz C15 Link
M.2: XPG SX8200 Pro 1 TB Link
M.2: ADDLINK S70 1 TB Link
PSU: CORSAIR SF600 — 600 Watt 80 PLUS Gold Link
GPU: ASUS Strix GTX 980 Link
Preparation:
I re pasted the GPU with Conductonaut
same was used for the CPU
Assembled everything outside of the case (obviously),
Fitting components in the case was pretty strait forward, cable management was fairly easy (for the size of the case)
My main issue was with the fitting of the GPU, a it is quite large, even after the installation of the optional brackets, bottom fan was still scraping in the cover
i had to stick a double sided foam tape on the GPU cooler to gain 1 mm of extra clearance.
Temps & Noise
Ambient temp: 24 C
Idle:
GPU: Temp: 30 C, Fan speed: 0
CPU: Temp: 37 C, Fan speed: 30% (min that can be set in M/B)
PSU FAN: 0
Noise: inaudible
Stress test GPU & CPU (GPU stock)
GPU: Temp: 67 C, Fan speed: 38% (178W)
CPU: Temp: 78 C, Fan speed: 100% (all cores at 4.3 Ghz / 75W)
PSU FAN: Running
Noise: Only CPU fan is audible, but not very loud or annoying (42 db)
Stress test GPU & CPU (GPU +100 Mhz core, + 200 Mhz memory)
GPU: Temp: 68 C, Fan speed: 42% (187 W)
PSU FAN: Running
Gaming (GPU +100 Mhz core, + 200 Mhz memory)
GPU: Temp: 68 C, Fan speed: 40% (187 W)
CPU: Temp: 55 C, Fan speed: 50% (all cores at 4.3 Ghz / 60W)
PSU FAN: 0
Noise: Only CPU fan is audible, but not very loud or annoying (38 db)
Photos
Parts used:
Preparation:
Temps & Noise
Ambient temp: 24 C
Idle:
PSU FAN: 0
Noise: inaudible
PSU FAN: Running
PSU FAN: Running
PSU FAN: 0
Photos
