UV Siamese is complete!
It is so named after the much sought and coveted deep UV purple coloured Siamese Fighting Fish
Now on with the build...
As many of you already may know the Darkside UV LED colour is actually a much darker deep purple and less pink than seen in the pictures. I replaced the Silverstone supplied eye-aching blue-coloured power indicator LED with a Darkside 5mm UV LED.
I just love the intense neon blue-green glow of the motherboard edge and other parts
The supplied USB 3.0 header cable was such a nightmare I finally just snipped it along with the unneeded audio header cables... I prefer the minimal look anyways and I have a handy little four port powered usb 3.0 hub I like to use. I replaced nearly 95% of all the silver coloured screws supplied by Silverstone with black ones and added some nice black thumb screws to make taking the cover on/off easier... I just couldn't find black-coloured fan bolts/screws that secure the Noctua to the fan bracket right above the CPU/Motherboard :-( and yes, that is a 25 mm thick case fan I squeezed in there!
The little engine that could... the tiny Thermaltake Engine 27 is working extraordinarily well though I am only using it with a Skylake Pentium at the moment... waiting for Kaby Lake. The Engine 27 is more noisy than my Cryorig C7, though not dramatically so. It has an interesting low machine-like hum that up until now has not been distracting to me... at least thus far. I had anticipated a more buzzing-like and/or grating-like sound but instead it is producing more of a low humming, refrigerator compressor-like, report.
HDPLEX 160W DC-ATX Direct-Plug with HDPLEX 80W Internal AC-DC Adapter
I have the CPU Cooler (Engine 27) and Case Fans (Two Noiseblocker 80 mm and Noctua 120mm) set at the lowest settings ('SILENT' mode) via the Gigabyte M/B bios... minimum and maximum temperatures noted for the past week plus as follows (my system is on 24/7):
CPU: 26 | 45 C
Case: 24 | 33 C
SSD: 25 | 35 C
M2 SSD: 38 | 55 C
(Please see temp update post on 29 DEC down below)
BUILD PART LIST
Silverstone Milo ML06B-E Case
Gigabyte H170N-WiFi
Intel Skylake G4400 Pentium (replaced with Kaby Lake Pentium G4600 3.6GHz)
Cryorig C7 CPU Cooler (replaced with Thermaltake Engine 27 CPU Cooler)
Kingston HyperX FURY DDR4-2133 (2 x 8GB)
Crucial MX300 M.2 SSD (275 GB)
Crucial MX300 2.5 SSD (525 GB)
Transcend 370S 2.5 SSD (128 GB)
Noctua NF-S12B redux 1200 PWM Case Fan (1 @ 120 mm x 25 mm)
Noiseblocker NB-Multiframe M8-P PWM Case Fans (2 @ 80 x 25 mm)
Silverstone ST30SF 300W SFX PSU (replaced with HDPLEX 160W DC-ATX Direct-Plug + HDPLEX 80W Internal AC-DC Adapter w/ HDPLEX Custom SFX Bracket with DC Socket Adapter)
Darkside UV Rev4 LED Strips (3x)
Darkside 5mm UV LED (Power LED Indicator)
Darkside SATA Power Adapter Cables
Silverstone Magnetic Fan Filters (120 mm & 140 mm)
Phobya 3-Way PWM Fan Splitter Cable
CableMod ModFlex Cables
Silverstone Tek 300mm Ultra Thin 6Gb/s Lateral 90-Degree SSD SATA Black Cables with Custom Low-Profile Connectors (2 x SST-CP11B-300)
Prolink HDMI Cable
Samsung SF350 21.5" LED Monitor
Logitech K810 Bluetooth Illuminated Keyboard
Logitech M325 Mouse
Logitech HD Webcam C525
UGreen 4-Port USB 3.0 Hub
Asus Xonar DX Sound Card (replaced with AudioQuest DragonFly Black USB DAC/AMP + AudioQuest JitterBug)
Bang & Olufsen BeoPlay H6 Headphones (replaced with Nhoord Audio Red v2 headphones)
CPU: 26 | 45 C
Case: 24 | 33 C
SSD: 25 | 35 C
M2 SSD: 38 | 55 C
BUILD PART LIST
Gigabyte H170N-WiFi
Prolink HDMI Cable
Logitech M325 Mouse
