GPU UHD on Thin Mini ITX?
Cyber Locc
30
Hey guys does anyone know of a Thin Mini ITX board that has the hardware needed to play UHD blurays?
So HDMI 2.0a, Kaby lake H CPU, SGX, and all that good stuff?
Also is there any slot loaded UHD drives yet?
a13antichrist
86
29
That's something I've been keeping an eye on too. Kaby Lake and even Coffee Lake only have HDMI 1.4 support in their iGPUs, however that is already enough for UHD. It's the 60Hz part for which you need extended support, or, like some ITX boards and the NUCs do it, an on-board chip to convert the DP signal to HDMI 2.0.
But all current 1151 Thin-mini boards (with DVI or DP) will already do UHD resolution to a display that supports it. I don't know anything about Bluray though, if that affects it in any way, perhaps HDCP 2.2 is needed and for that you do need HDMI 2.0a I believe. Your solution in that case would be a $30 "DP -> HDMI active converter", made by Club 3D. I forget if I'm allowed to link to shopping pages, so, I'll just let you google/amazon that manually.
maeslin
AFAIK and according to this thread, the AM4 mini-itx boards, when matched with a Raven Ridge APU (2200G, 2400G) are HDMI 2.0 and HDCP 2.2 compatible, so they should handle UHD content just fine.
Cyber Locc
30
There is as you said ITX board that offer HDMI 2.0a via a Display port adapter chip. They will play UHD, but no thin minis that I can find :(.
The adapter doesn't work, as there is some magic required :(.
To play UHD on PC you need.
AACS 2.0
HDMI 2.0a
DHCP 2.2
All of which have to be enabled on the driver for the GPU (Only exists with Intel 630+ GPUs)
Also you have to have SGX Support on the chip and the board.
As of this moment, UHD will never be able to be played on Ryzen. It requires SGX, which is Intel properitary. Intel makes the HDCP 2.2, so they kind of have free game to do stuff like that. Unless they change the UHD standards or Intel changes its mind, and drops the SGX (unlikely) you will never be able to have native UHD playback on Ryzen.
You can do that decrypt/play stuff, however that isn't going to work for every movie, and it involves hacking the Copyright Protection of the disc.
a13antichrist
86
29
To be precise, UHD --Bluray--. AMD processors can of course play any UHD you happen to have sitting around in an MKV or whatever.
AMD have also said that they will be releasing PlayReady 3.0 drivers later this year in order to enable UHD HDR in Netflix.
Reactions: ColorZepppelin
GuilleAcoustic
Chief Procrastination Officer
LOSIAS
Jun 29, 2015
2,975
4,402
guilleacoustic.wordpress.com
Nvidia GT1030 works fine on my thin-ITX Q87T with a 90° riser. It provides HDMI 2.0 and stays thin with the riser. No stability issue and do not need powered riser.
I use a Zotac low profile single slot one with a 35w i7-4785T (iGPU disabled so it draws only 25w) and powers the rig with a 90W Dell power brick.
Reactions: jØrd
7,151
