Hey guys, this is my first attempt at a custom loop so excuse the im-perfections from the build.
At 24.5L, the core G3 is hardly an SFF case, but it only supports SFX PSU so it stands in a weird spot.
Anyways, if you follow any of my other post, I've mostly dealt with and experimented with all sort of janky air-cooling solutions.
This is my first experience with a custom loop, but being a tinkerer, that didn't stop me from trying out so many different configurations (rads, fans, blocks, etcs) before getting to where I am now.
Was looking real hard trying to find a case with lots of radiator space. Upon first look, this case only offer 1 240mm front mounted rad. But after looking at a few projects from other people, a 360mm rad can be front mounted with a bit of modding, I was intrigued. I further experimented with the case and was able to fit a total of 3 radiators in this case! (360mm front, 240mm top, and thick 54mm thick 120mm bottom).
I was hell bent on trying to fit as much radiators as I can because I'm running a 9900k and 2080 Ti, both overclocked to 5Ghz and 2.1 Ghz respectively. At the same time I want to run lots of fan at low speed. (Tuned for 1000 RPM).
This is my first attempt so I didn't want to go for a hardline, and to be honest, it would've been a wasted effort as not many "line" are visible from outside the case. That and it was REALLY cramp by the time I finished, soft-tubing helped a ton.
The rest of the loops:
CPU & GPU blocks : both Heatkiller IV (Cooper).
PUMP: Corsair Hydro X D5
Fittings: EK
Fans: 6X PH-F120MP_BK_PWM
Rads: HW Labs Nemesis 360mm, XPSC TX240, HW Labs GTX 120mm
Command Pro for coolant measurements and fans control
Results: Underload Gaming Load ~ 400w ( GPU 3-330W, CPU 50-100W) after 30 mins (Divison 2)
Room Temp: 27C , Coolant 43C, CPU ~60-65C, GPU 53C
After 30 mins warm up: Cinebench score ~2150. Temps peaked at 85C.
Cable manage was difficult, as there's no separate chambers for cables. It's messy, but I tried my best to keep all the cables at the bottom of the case near the SF750 PSU.
I didn't take as many pics as I was constantly trying new stuffs and was just damn exhausted by the time I got this build together. Just happy that it's running with no leaks
I'll gladly take more pics per request if anyone has any questions on some of the mods I did.
Fittings: EK
