The future of Socket 2011
6,128
5,033
Belgium
So when Socket 2011-3 is replaced, probably in 2018, this might make the Cerberus-X more appealing: https://www.servethehome.com/big-sockets-look-intel-lga-3647/
I introduce to you: Socket 3647. In the picture, the hand is holding a socket 2011-3 CPU, alligned at the bottom-left corner.
This might make it even more difficult for modern enthusiast-class boards to be developed in µATX format.
EdZ
Virtual Realist
May 11, 2015
1,577
2,108
UK
Socket 3647 is intended for Knights Landing, due to it's obscene IO capabilities (and massive die). I don't think there's any intention to use it for the normal Xeon line, just Xeon Phi.
I'm not even sure it'd be a good idea to use Knights Landing itself for a desktop machine: while it has plenty of cores, those cores themselves are pretty slow (Airmont Atom cores, at half the clockspeed of even the slowest mobile Celeron).
6,128
5,033
Belgium
You bring up a good point, I thought this was meant to replace socket 2011-3, according to the source. But as I dive deeper, it seems Intel is going to be using one socket for enterprise 2-CPU up to 8-CPU and there will be a different socket for the now X-denomination instead of the E-denomination.
Reactions: Soul_Est
