Hi,
I would like to provide the best set of case fans for my A4-SFX. Could you help me?
These are my components:
ASUS ROG STRIX x470-i
Ryzen 2700 + Noctua L9a-AM4 cooler (during the gaming = about 65 °C, so I am happy with it)
GIGABYTE WINDFORCE RTX 2080 (during the gaming with ultra settings = max 80-82 °C, I would like to reduce it)
M2 nvme ssd Samsung 970 evo 500 gb under Asus M2 radiator (about 53 degrees, it would be good to reduce it)
2,5" SSD Samsung 860 evo 1TB (If I remember correctly about 46°C)
G.Skill 3200 Mhz 2x16 gb
Corsair SF600
The whole PC is very quiet, until the intense gaming. Then it's audible, but it does not bother me (under load It's still quieter than my old gaming laptop ) . I would like to reduce the temperature of the graphics card (without losing performance) and possibly m2 ssd.
In the m2 ssd case, I know that I can use one or two Noctua NF-A4X20 40mm (?) but I do not know if I can mount at least one without modding or 3d printing.
My other options for better cooling of the case are:
-a fan below motherboard (which one? - I heard that small fans at the bottom don't do anything.. ) ,
- below PSU (Noctua NF-A9x14 PWM or Akasa 80x10? ) now I have 2,5" ssd in this place, but I know that I can move it to the front of the case.
- a fan above the PSU (which one?
Noctua NF-A9x14 PWM, Akasa 80x10? )
- above the mobo [Noctua NF-A4X10-FLX 5V (12V is better ?)?]
I have also found anidees AI HALO RGB 80mm LED Case Fans (8 x 8 x 2,5 cm). It would be nice to mount at least one of them on the top of the case, but probably they are too thick?)
I also have AMD Wraith Spire cooler from Ryzen 2700. Theoretically probably I could mount it below the psu, but in this case, I could only benefit from RGB by mounting Wraith on the cpu (or on the top but it is probably impossible). Maybe someday I will do it, if I widen the housing by adding custom Window plexi. But by then it would be nice to have a rgb fan for example on the top of the case.
First of all, I would like to lower the temperature of the RTX 2080. Secondly, lower the temp of m2 ssd.
In addition, the aluminum case is hot when touched, but probably I can't do anything about it.
I would like to lower these temperatures by some sensible value, and not just spend money, that's why I'm asking you for advice
Corsair SF600
