The best case under 7L
angga456
Hello guys, I am searching for the best case under 7L or under 6L that can fit Mini RTX 2060. also, it has to be slim, thank you to you all who answered this thread.
ignsvn
By Toutatis!
1,833
1,753
Earth
not at all,
In your previous post you mentioned that you didn't want to go over $100 for the case alone, and you prefer to use SFX PSU (https://smallformfactor.net/forum/threads/any-good-cases-for-mini-itx-build-under-10-l.12809/). If now you are OK with going over $100 and using external power brick, then yes NFC S4 is good solution, but it won't fit your Ryzen R5 3600 stock cooler. I also see that your volume requirement has now shrunk.
We'd like to help you, but please state your (updated) requirements:
- what size of motherboard? (I assume it's still mini ITX)
- what size of GPU? dual slot? triple slot? full height? half height? single fan? dual fan? triple fan? (I assume it's still the same, MSI RTX 2060 ITX Aero)
- how many hard drives (3.5" / 2.5")? (I assume it's still the same, will be using M.2)
- what's the minimum CPU cooler height?
- preferred PSU type? SFX, ATX, Flex, Meanwell, etc?
- preferred case material (acrylic, aluminum, steel, etc)?
- case budget?
ignsvn
By Toutatis!
1,833
1,753
Earth
Other than that, our friend @prayogahs made this excellent list, probably can help you:
TL;DR:
Original thread:
