Thought I'd make a thread for my ongoing experimentation with an STX + gpu build. It won't be in a fancy case like like Aibohphobia's build, but I may make a simple enclosure out of acrylic to case the gpu and PSU etc!
I will update this thread as I experiment more with various stuff and progress towards a finished build
The ultimate goal is to power all the components through one power brick, although for reasons discovered by other members of the forum this may not be possible with the currently available picoPSUs on the market (Motherboard takes 19V DC input, graphics cards need 12V DC input, not many wide input picoPSUs on the market that are capable of powering a high end gpu).
Parts Ordered/Owned (some may or may not be used in the final build)
ASRock DeskMini 110 case and 120W adapter
ASRock H100m-stx motherboard
Intel i5-6500 CPU
1x 8GB RAM ddr4 sodimm
MSI GTX 750 ti low profile (might buy a 1050 ti to upgrade)
Gigabyte GTX 970 mini (going to try it out as well)
Bplus P4SM2 m.2 to pci-e x4 adapter
generic 16x pci-e extension cable
generic powered 4x -> 16x powered pci-e extension cable (going to see which one works better)
Corsair SF450 PSU (to power graphics card temporarily until a new solution is found)
Thread contents
1. Intro (Case pictures / PSU / Cable discussion) (this post and following posts)
2. Pics after installing CPU/RAM onto motherboard
3. 5.5x2.5mm DC connectors tested/wires
4. Pic of motherboard / low profile graphics card
5. Powering both the motherboard and gpu off 1 adapter
6. Cardboard mockups of how the enclosure might look
ASRock DeskMini 110 case opened up
I'm glad that all sides of the case are separate pieces held together with screws, should be good for modding
I think it was worth buying the case instead of just the motherboard, since the motherboard plate is pretty awesome (pictures in the spoiler)
Intel i5-6500 CPU
Thread contents
