My R5 3600 hasn't been having a very good time under it's stock cooler (in a Dan A4 v4), going 90+ degrees in a synthetic benchmark. I was hoping to upgrade to an Asetek 645LT to resolve this heat issue and maybe get a bit of an OC in.
I did some digging and this AIO setup needs a 3-pin header for the pump and a 4-pin for the Noctua fan. My case has two 4-pin headers but only the CPU one works sadly. Now I found out that Noctua fans come with a Y-splitter but I'm unsure if that has any negative side effects.
- Is it bad to mix a 3-pin pump and a 4-pin PWM fan on a y-splitter?
- Would I have to set my motherboard fan control to voltage mode instead of PWM?
- Also are motherboards able to give enough current to both a fan and a pump on just a single header?
