I have some hardware from my old gaming PC that I would like to recycle into a SFF PC that I can take with me on different LANs. I initially bought a Jonsbo C2, but it turns out that it only supports FlexATX and smaller. That was a big bummer for me since my build is using an 1156 socket (ancient, I know, I know but look at the prices for the Xeon X3430 and X3440) and every FlexATX mobos that are available do not have the features I'm looking for, or costs too much to be worth it. I was looking at the Jonsbo/Cooltek V4 but I was wondering if there was any case possibly smaller than that.
What I need is the smallest mATX case possible with full sized PCIe brackets, space for an ATX PSU, an Intel stock cooler, a GPU with 170mm length and 2 2,5" drive mounts.
(Yes I know many requirements but I want this to be gud)
I'm aiming to find one below or around 18 liters, under $100 if possible.
EDIT: I went with the V4 in the end. Very small but just as fragile since aluminium.
Thanks in advance!
Thanks in advance!
