smallest itx case for 212 evo
oldnick
hi
I am looking for smallest case possible to fit my 212 evo (160mm)
also it has to have sfx psu mount not atx (since i already have the sfx psu) and preferably not too long gpu clearance "my video card is evga gtx 1060 sc which is less than 7" long
also no hdd\ssd or 5.25" bays needed (have m.2 drive)
thanks
matt3o
113
268
out of my mind
- rajintek metis plus
- Kolink Satellite
- cougar QBX Kaze
all with ATX to SFX adapter.
oldnick
out of my mind
- Kolink Satellite
- cougar QBX Kaze
thanks but Kolink Satellite and cougar QBX Kaze seems too large
rajintek metis plus looks very good but does it include atx to sfx adapter ? (still want a native sfx psu support so i wont waste space inside the case
Reactions: Rikardo
matt3o
113
268
If you want 160mm CPU cooler compatibility I don't think you can go much smaller than that. I'm sure there's some other case around you can use, but won't be super compact.
The metis does not support SFX natively and you need to buy an adapter.
