Hey everyone
First post, please bear with me ?.
Since April I've had a dream of building a mini-beast. I've been looking heavily into the Dancase A4, and also looking at new concepts in the making as the C4.
I searched the forums, but there doesn't seem to be any dual AIO builds with the A4 - which would be stretching it in such a small case already.
Anyhow, I'm looking for advice on the smallest footprint mini-ITX case that will fit a full size GPU and dual AIO cooling (GPU/CPU).
I want to fit the following hardware:
Gaming grade i5 (if budget allows I'll go for i7, if budget and PSU allows, I'll go for i9).
Full size RTX 2070S
1 NVMe SSD (M.2 or not, depends on mobo).
And an AIO cooling solution for GPU and CPU.
Can it be done in a case that will fit in a regular sized backpack?
Your efforts are much appreciated, thank you
//Zokeh
Full size RTX 2070S
//Zokeh
