Hello Lads,
this is the newbie speaking. After years of building always Fractal Define it's time for my first SFF rig. First i wanted to go with the LianLi Q58 but as i prefer air cooling i finally decided to move over to Sliger. I already got most of the components, only case and CPU are missing. For the PSU i want to order custom cables at BigRay
At the moment this is my build config:
Personally i prefer the SM560 over the SM620, but im worried in terms of temperatures and noise if th SM560 can handle the 5800X3D. My plan would be to UV the 5800X3D and work with the Noctua Fan duct or even going for the smaller CPU.
So what do you think ? Will the SM560 config work out or should i play it save and go for the SM620 ? I've already checked @MarcParis Build logs and the SM620 should be fine, but how about the SM560 ?
Appreciate every idea and suggestion. Will then later if wanted post the build log :-)
br
Schubdog
- Asus Rog Strix B550-I Gaming
- AMD Radeon 6800 XT Reference
- Corsair Vengeance RGB RT Gunmetal DIMM Kit 32GB DDR 4-3600
- HP EX900 NVMe 500 GB
- Kingston KC2500 NVMe 2 TB
- Sandisk Ultra 500 GB SSD
- Cooler Master V850 SFX Black
- CPU
- AMD Ryzen 7 5800X3D
- AMD Ryzen 7 5700X
- Case
- Sliger SM560 White
- Cooling: Noctua NH-L9a with FanDuct
- Sliger SM620 White
- Noctua NH-U14S
- Noctua NH-D15S
br
Schubdog
