Hi all,
As you might know, my last build log, based on Sliger CL530, led me to some frustrations as I failed to reach my expections with this case & hardware I put inside :
Check build log here
https://smallformfactor.net/forum/threads/sliger-cl530-tame-rtx-3090-fe-build-log.16125/post-238653
At the end, I didn't have any love in CL530 (dislike Cerberus-X).
Thus I decided to follow a different approach by giving a try (and hopefully succesful one) to Sliger S620.
Hopefully case was available in stock from Density.sk (thanks again @shadowfear)
Here are links to Sliger S620 web pages
https://sliger.com/products/cases/s620/
https://www.density.sk/product/sliger-s620-mini-itx/
Concept of Sliger S620 is pretty straight forward : Carry over Cerberus layout to mini-ITX with improvement & noticeable support of Noctua NH-D15 cpu aircooler & rear 120mm fan slot.
Here are interesting videos related to S620 :
Your first comment shoud be then : Why Sliger S620 over Cooler Master NR200?
Well, 2 main reasons made me choose S620 :
Here are components I will use in my setup :
Let's start assembly, shall we?
Important note while using RTX3090 FE in S620, please follow those steps :
Finally the most difficult part of the assembly is to assembly PSU & bracket, but nothing impossible, by far.
Let's get back to my specific build...
I tried already 2 different setup for fans :
As usual I used Control as benchmark.
Here are results :
Here is a long gameplay session with Assassin's Creed Valhalla (without issue of fixed fan speed on cpu cooler..)
Here are pictures of setup #2 build :
Overall I'm still positively surprised that Sliger S620 is performing (cooling & noise) in similar range with my sweet Cerberus-X.
This later is keeping some advantages (ease of assembly/disassembly, easy addition of storage, etc...) but it's obvious Sliger S620 is true heir of Cerberus case family!
As you know me well, this is only my first setup inside Sliger S620, like with Cerberus-X.
I'm already thinking of a new cooling setup, especially I met a new challenge with Resident Evil Village, where RTX 3090 FE can be using up to 350W (even with my optimised vcore!) almost in continue..
But that will be a story for another day..
Update 20th May 2021 : Sliger S620, SFF King of Benchmarks (CPU, more gameplays)
Here are additional benchmarks within Sliger S620.
At first I've tested in pure CPU cooling, using Intel Burn Test 2.54, Very High Profile.
I've tested with 2 fan speeds :
Here is updated IBT 2.54 Very High CPU benchmark :
Regarding CPU cooling performance, nothing to say that, except that Noctua D15S is king of the hill in my SFF experience.
Only strong watercooling (240 or 280) could provide equivalent or better cooling..
I'm very impressed again by Sliger S620 as it can fit easily this infamous D15S..
Here are screenshots :
On top of that I've also tested Sliger S620 in Cyberpunk 2077. Once again thermals & noise were great (especially vs CL530) :
In addition I've created dedicated Youtube palylist with my monitored gameplays :
At last I've finally created a compelte Imgur Album/Post :
What about cats?!
- Sliger build quality : S620 is already 4th case from Sliger. Their 100% metal construction makes them very durable. My past experience with Cooler master cases or products...well...well...not so successful.
- More compact & more assembly options :
- "Noctua D15" but mostly 120mm rear fan option
- 3xSFX positions
- Front, back panel fan positions
- Based on my Cerberus-X experience, I love playing with setups within same case
- CPU : AMD R7 5800X, stock
- MB : Asus B450-i Strix
- RAM : Corsair Vengeance LPX 2x8go (16-18-18-18-36)
- GPU : Nvidia RTX 3090 FE, tamed 1800Mhz@0.806v (GDDR6X +250Mhz, stable but leading to higher temperature, thus I leave it stock). Resizable BAR enabled
- SSD #1 : Samsung 840 Pro 240Go (2.5", Sata, System, GPT)
- SSD #2 : ADATA SX8200 Pro 2To (m.2, nvme)
- CPU cooler : Noctua D15S Black Edition
- PSU : Corsair SF750 (stock cables)
- Put Motherboard without cpu cooler (MB back panel cutout is perfect!)
- Put RTX3090 FE in position (good news, not external AC plug..)
- Put case fans in place (I tried TOP double slim top, a bit too optimistic with D15S..)
- Put PSU & its bracket in position
- Put CPU cooler without fan
- Add CPU cooler fan (Fan retainer CPU cooler are imposing significant constraint)
- Setup #1: Rear intake with side & top exhaust
- Rear : Noctua NF-A12x15 intake
- D15S : Noctua NF-A15 "intake"
- Side : Noctua NF-A12x15 exhaust
- Top : Noctua NF-A12x15 exhaust
- Setup #2: Full exhaust
- Rear : Noctua NF-A12x15 exhaust
- D15S : Noctua NF-A15 "exhaust"
- Side : Noctua NF-A12x25 Sterrox exhaust
Here are results :
- Setup #1:
- RTX 3090 FE :
- Power draw : 300-320w
- Fan curve : customed
- Fan speed : 1265 rpm
- Core : up to 68°C
- GDDR6X : up to 104°C
- R7 5800X :
- Power draw : 70w-75w
- Core : up to 65°C
- Noise :
- Rear 120mm slim intake is just HORRIBLE, ruining this fan setup completely!
- RTX 3090 FE :
- Setup #2:
- Special note : by mistake I fixed CPU cooler fan speed to 630rpm..
- RTX 3090 FE :
- Fan curve : stock
- Fan speed : 1134 rpm
- Core : up to 63°C
- GDDR6X : up to 102°C
- R7 5800X :
- Core : up to 70°C (it's below 70°C with not fixed CPU cooler fan..)
- Noise :
- Rear 120mm slim exhaust is now OK
- Side NF-A12x25 (Sterrox) is rocking as quiet side exhaust..
- Quiet gaming at around 300-310W GPU power load, on full air cooling..
- CPU Fan following PWM curve, NF-A15 is reaching approx 900rpm maximum
- CPU with NF-A15 with its maximum speed (1500rpm)
- Stock R7 5800X RAM @ 3200MTS (S620, Noctua D15S with NF-A15, Max Speed, 1500 RPM), average all cores clock of 4450Mhz approx :
- IBT 2.54 Very High : 759.61sec (3.7% faster than R7 5800X in CL530)
- Max temperature : 70.1°C
- Max CPU Package Power : 134.88W
- Stock R7 5800X RAM @ 3200MTS (S620, Noctua D15S with NF-A15, PWM Curve, 900 RPM), average all cores clock of 4350/4400Mhz approx :
- IBT 2.54 Very High : 763.66sec (3.3% faster than R7 5800X in CL530)
- Max temperature : 76.4°C
- Max CPU Package Power : 134.75W
- Stock R7 5800X RAM @ 3200MTS (CL530, Noctuaed IS-60 EVO), average all cores clock of 4250Mhz :
- IBT 2.54 Very High : 789.41sec (13.8% faster than R7 3800X OC 4.3Ghz)
- Max temperature : 86.3°C
- Max CPU Package Power : 133.36W
- Overclocked R7 3800X 4.3Ghz @1.3125v RAM @ 3800MTS (Asetek 645LT Intake, Side Exhaust) :
- IBT 2.54 Very High : 915.72sec
- Max temperature : 78.9°C
- Max CPU Package Power : 120.03W
- Overclocked R7 3800X 4.3Ghz @1.3125v RAM @ 3800MTS (Noctua C14S Push/Pull Intake) :
- IBT 2.54 Very High : 915.80sec
- Cinebench R20 (multi) : 5120
- Max temperature : 73.9°C
- Max CPU Package Power : 119.23W
- Overclocked R7 3800X 4.3Ghz @1.3125v RAM @ 3800MTS (customed 92mm watercooling, push/pull) :
- IBT 2.54 Very High : 917.12sec
- Max temperature : 79.5°C
- Max CPU Package Power : 118.33W
What about cats?!
