Log Sliger S610 WIP
TheHig
951
1,171
Hello everyone,
Here is a quick set of pics for my S610 build in progress.
Specs:
5600x
Wraith Spire cooler
Gigabyte B550i mobo
32Gb Crucial Ballisix DDR4 3600
1Tb Samsung 970 evo NVME
2Tb Inland Premium NVME
Gigabyte Aorus 2080ti Extreme
Corsair SF750
Sliger S610 chassis
I put it all together tonight to break it in and start those Steam downloads . All that is left is an exhaust fan for the top and, still deciding which, a CPU cooler. Some cable management to finalize as well. The case is very easy to build in especially if you have built in a Sliger case previously.
Thanks for looking!
2,668
2,792
Very nice, good job shoehorning that GPU in there. So what are your thoughts on the S610? I am really tempted by this case.
murtoz
It's a baby Cerberus! Nice build, looks like you really had to convince that GPU that it actually fit!
I own the Cerberus as love it to bits. Can recommend!
Swap a black power button with red light - makes it a whole other case :)
Wait, that *IS* a different case! But the effect gets even better if you add a red top cover I think 😁
Reactions: TheHig
TheHig
951
1,171
Definitely a nice case. I like the proportions of 610 vs the 620 personally. Fans are audible under load but temps are good. I plan on trying the c14s I have for the cpu. That or I order the U9S chromax. Either are fine for a 5600x. The wraith spire is good enough really if a bit loud.
TheHig
951
1,171
Back again and finalizing the build for now. I decided to go with the C14s since a cooler in hand is better than 2 unpurchased.. or something. Anyway I'm calling it a success and recommend this type of setup for anyone in the S610.
