Project Mercury - An internal watercooled Skyreach 4 Mini
Will you pay 300$ USD for a motherboard monoblock that have pump and resivior intergrated into it?
  • Yes
    Votes: 60 69.0%
  • Way tooooo expensive
    Votes: 17 19.5%
  • *Rember, you saved on fittings(at least 2 of them), pump top, and reservoir with an AIO like this*
    Votes: 10 11.5%
  • Total voters
    87
  • Poll closed .
KMPKT
3,382
5,936
The one commentary on this is that the crossflow from the fan that would normally vent through the lateral vins is going to be pretty hindered by the fan frame. Any thoughts on putting a normal VGA fan inside instead?
1461748123
489
1,068
I never work with those fans before, but I guess they will be a better choice!
I don't wanna use those crappy generic fans... So I guess I will end up with copping the shroud off the noctua slim 120mm haha
1461748123
489
1,068
Just got a message back from the CNC guy, to his experience the thinnest GPU block I can do is 8mm. This leaves about 32mm height for the heatsink to sit in.
If the CPU water cool project is successful and manage to control the CPU temp in a reasonable range, I will definitely try water cooling the GPU as well with this method!
1461748123
489
1,068
Another sketch with a round fan, as well as a diagram explanning the idea:
As you can see, the top part of the waterblock is basically the heatsink as well. The fittings can be directly screw into the top part with a g1/4 thread.
Edit: Make the cuts vertical instead of horizontal. Since the card will be standing up, this will allow more air to escape
But now there's another problem, the air won't be able to pass through all the fins.. gotta figure out a way to resolve this
owliwar
Lazer3D
Apr 7, 2017
586
1,082
Maybe try something less dense for this gpu heatsink? The air will move easily, it may saturate faster but you will use it with the radiator. There are gpu heatsink smaller than this doing ok. Remember it's hybrid card :) how much vertical room you have on the skyreach 4 mini? Just curious
1461748123
489
1,068
I will do some thermal simulation, just need some youtube tutorials now :p
There will be ~40mm in the S4M for the GPU heatsink :D
1461748123
489
1,068
Update 2/9/2018
A care package has arrived! :D
Got the brackets :p unfortunately, they forgot to mill the sides down, which made the brackets a bit too thick
Well, at least the screw holes fit!
Also got a really shiny IHS:
Will test out the performance latter haha
This will be the last update(likely) before March due to Chinese New Year. All of the manufacturer and companies will be on holiday.
KMPKT
3,382
5,936
Is that IHS simply aesthetic or does it somehow confer superior heat transfer?
1461748123
489
1,068
To be honest, probably only for aesthetic :p But, to its credit, at least it has a mirror finish to it, in theory, should provide better heat transfer
1461748123
489
1,068
Update 2/19/2018
Got the EKWB waterblock today, I can finally verify if a single, or dual 40mmx3 radiators will be able to handle an 8700k :p
It's kinda a bummer when I realize that the block isn't machined out of a single piece of copper! Another reason for me to make the block myself :D
Tanax
88
58
Subscribed to thread and following with interest!!
Most important to me is, of course reasonable temperature, but also not taking up too much space.
Doing things custom made for the S4M should enable use of space more efficiently so this project will be very interesting.
Reactions: 1461748123
1461748123
489
1,068
Update 2/22/2018
Put everything together in an extremely janky way:
I'm using two separate PSU for the setup. One for the hardware and one for the cooling stuff. This way I can keep the pump running without turning on the system.
I'm using 40x20 server fans. They are LOUD, and they are there because my Noctua 40x10 fans haven't arrived yet :p
I did a quick stress test to see if this will even work. And the result is really.. random. I'm experiencing an idle temperature of 40~C and suddenly went up to 60 or even 70. When doing the stress test, it sometimes stays really stable at 80-90~C but sometimes it just jumps above 100C and throttle. I believe this is because there are a lot of bubbles trap in the block, and I can still see them going through the tubes from time to time. I will leave the pump running overnight to hopefully remove all the bubbles and do a proper stress test tomorrow.
I'm only using one radiator now :p The idea is, if one radiator can handle the CPU without problem, then two will just be better XD
The bubbles:
489
1,068
Update 2/23/2018
This morning I woke up and most of the bubbles are gone!
The system stables at 40~C while idle:
But while on full load, stressing both CPU and FPU, the system hits 100C after 10 minutes, and are experiencing thermal throttle up to 15%
This means I need at least two rad to handle the 8700k comfortably.
But I haven't undervolt the CPU yet, also, since I'm using ASUS motherboard, multicore enhancement are enabled by default (basically a slight overclock).
I will add another radiator in this afternoon and see how the temps will look like!
BernardoZ
Founder of Z-CASES
z-cases.com
Feb 7, 2018
264
490
www.z-cases.com
Wow, this is awesome man, really! Temps are also very good.
Just one question. Why did you choose using a separate reservoir? Wouldnt be easier and smaller-size just picking a cpu/pump/res combo unit from an existing AIO, and adapt on this radiator? Just wondering, dunno if that would work.
Cheers ;)
1461748123
489
1,068
Cheers ;)
It's just for testing purposes :p easier this way to add liquid and maintenance. It won't be there in the finish build :p
Reactions: BernardoZ
BernardoZ
Founder of Z-CASES
z-cases.com
Feb 7, 2018
264
490
www.z-cases.com
Nice! Just a heads up:
We are trying to do something similar in our project (but with Dual 60mm Rad), and this "cpu/pump/res combo unit" thing is being a pain in the ass. Using those is the only way we can make watercooling support fit, but it seems Asetek has a patent for it on U.S (I have to confirm it). Also, you can't buy those (at least not the low-profile ones) separetely on the market, they only come included on AIOs.
We are trying to solve this problem, so I'm curious how you gonna deal with it, or if you will just end using a separate reservoir. ;)
Cheers
Reactions: seto and 1461748123
1461748123
489
1,068
Cheers
Ha, I'm planning on making a monoblock with a pump as well as reservoir integrated into it. It will be a bit longer than the one I'm using now and will cover the M.2 slot as well :) That way I can fit everything into a tight unit without wasting too much space.
Reactions: seto and BernardoZ
