This has taken more than I wished, just too busy, but finally pulled it off!
Parts
Ryzen 7 2700X
ASUS ROG Crosshair VII
2x 16GB Corsair Vengeance RGB Pro DDR4-3466
Vengeance RGB Pro Light Enhancement Kit
NVIDIA 2080 TI FE
Corsair SF750 Platinum
Samsung 970 EVO 1TB NVME
Samsung 970 EVO 2TB NVME
Samsung 970 EVO 500GB NVME
Samsung 970 EVO Plus 500GB NVME
Bling: 2x 30cm ROG Led Strips
Watercooling Parts (I had Alphacool GPU and CPU AIOs in storage, so the GPU block and 2 radiators were taken from those)
EK-WB ASUS C6H RGB Monoblock - Nickel
Alphacool GPX-N 2080 TI M02 (with integrated LT Ceramic Pump)
Alphacool 240x25mm Radiator
Alhpacool 240x30mm Radiator
Alphacool Eisstation DC-Ultra Reservoir with DC-LT 2600 Ultra pump
Mostly Alphacool G1/4 fittings for 10/13mm soft tubing with some EKWB parts and one XSPC extension with water temp sensor
Alphacool HF tubing (don't have UV lights but like the frosted effect)
4x Noctua NF-A12x25 PWM
EK-CryoFuel Navy Blue Premix
The Build
Preparing rads and GPU block
GPU ready for the block
Motherboard ready for the moboblock and after install
I actually realized checking the photos later on that because 2 of the mosfet heatsink screws are not accessible, I will have to drain the loop and take everything out to upgrade my CPU
Fitting everything in and cable management
That is kinked, had to redo it
Leak testing
And 1 fitting on the bottom rad leaked, lots to cleanup but no damage, just mess.
Leak testing take 2 (it's all good!)
Left it like this for a few hours to be sure.
Final build
Superposition 1h stress test
CPU boosted well, no special sauce, just Precision Boost on Auto and VCore at -0.100 offset.
Getting that water temp sensor was a great idea as once connected to the mobo you can set fan and pump curves based on it.
Still playing around with it, will probably bench more later
Parts
Ryzen 7 2700X
NVIDIA 2080 TI FE
The Build
Leak testing
Final build
