we all know - potent ITX sized GPUs are hard to find and/or very expensive these days but that shouldn't stop us from having fun building SFF rigs, right?
for this build in the RCC-MIT1 prototype I am using only available and budget components, so lets get started!
first of all I needed some new fans and a nice cooler for this build. Silverstone had a great discount offer over here (buy two get 10% off, buy three get 20% off, etc.) so I went all in...
secondly I needed a new SFX PSU - I decided to go for a 350W Thermaltake unit which just cost me 25 USD
the PSU will only have to power an i5 6600K and some low spec GPU for now so that's more than enough wattage - only problem are all those unnecessary cables - but that can be solved...
I cut off everything I didn't need for my build and then insulated the cable ends properly with shrink tubing
I wasn't sure yet if I might need the PCIE power connector one day, so I decided to make it modular using XT60 connectors
after a little bit of soldering and shrink tubing - modding complete
next step: getting the motherboard ready and mounting that Silverstone Whopper on top
before moving this monstrosity into the case I mounted the case feet, fans, power button and of course my modded PSU
btw, those 60mm Silverstone fans are awesome... at full speed they might be a bit more noisy compared to Noctua but they have a 0-RPM mode!
having 12mm clearance I could route the fan cables under the motherboard...
in the automobile industry we called it "Hochzeit" when engine and chassis were finally combined - moving the motherboard assembly into the case reminded me somehow of this
at that point I whished I had used a fully modular PSU so I could plug in the cables before moving the motherboard in the case... luckily I have small hands
next time I'll plug the cables in first...
...but seeing that everything fits like a glove was definitely worth it
the GPU is still missing (just using a blank I/O shield for now) but I'm already very happy how it turned out:
bonus picture: thermals and fan speed at 30C ambient during CPU/iGPU stress testing
I hope you enjoyed the build log so far - to be continued once I get the GPU...
