On a lark, I purchased a Silverstone SUGO 16 PC case. This is the cheapest and only mass produced case I have purchased. I liked the component configuration with an SFX power supply and two 120mm fans for front to back air flow using an air cooler and shorter length graphic cards, and had already tried out an inverted layout in the Sliger S610. Yes, it is formed from stamped steel panels, but I was pleasantly surprised in the overall quality of construction. The filter holders inside the front and right side panels are nicely made. The vent pattern under the top panel filter has a nice pattern with no screw mounting holes or other indentations when the filter is removed. The two side panels are interchangeable. I would have liked to have had the same vents on both side panels – just for appearance. Also color choices – black or white. I would prefer to split the difference and have either a silver or gray color case. I was also glad no case fans were included – I wanted to select my own.
I installed my current testing rig with the Noctua D9L cooler:
Aorus B550 ITX MB; Ryzen 7 4750G; 32 GB Corsair LPX 3200 RAM; Metal block over NVMe drive not installed;
PNY RTX 3060 Graphics Card – Self Regulated
Front Intake Rear Exhaust – All fans at 100% PWM unless otherwise noted
Noctua NT-H1 Thermal Paste
CPU-Z Stress Test & Unigine Valley Ultra Settings for 10 minutes
Room Temp 21C;
Temp Sensor TZ10 read 16.8C on all test runs;
One specification that is not listed is how tall can a CPU cooler be before it starts to be blocked by the SFX power supply. That is approximately 112mm. A Noctua D9L cooler at 110mm is completely exposed to the front 120mm fan airflow. With the D9L cooler installed there is enough space to mount a 30mm thick Phanteks T30 on the rear panel. Using Corsair LPX memory also ensures that the lower CPU cooler fins are not blocked on the front side of the cooler. There was not enough clearance to install a second (front) 92x25mm fan on the D9L as the fan has to be set higher on the cooler to clear the RAM and will not clear the PSU connectors/wiring. Any tall slim CPU cooler such as the Noctua NH-U12S with a rear mounted fan should be a simple install. As the case is rather deep with only complete access to the interior of the case from the right side, attach all motherboard connections outside the case including the front I/O connections. I used a splitter cable on the motherboard for easy access to connect the two case fans after installing the motherboard.
For testing I had only two pair of identical 120x25mm fans – the Scythe Kaze Flex Black and the Arctic P12. The Kaze Flex are noisy at higher RPM but move quite a bit of air so I also tested them at 50% PWM / 1000 RPM. The front case filter made a substantial noise reduction with the Kaze Flex fans, not with the P12’s that are quieter than the Kaze Flex at all speeds. This may be the ideal case for comparing 120mm case fans in matched intake and exhaust pairs.
CPUID HWMonitor Readings:
Room Temp 21C;
CPU Cooler | Noctua D9L | Noctua D9L | Noctua D9L | Noctua D9L | Noctua D9L |
GPU | PNY RTX 3060 | PNY RTX 3060 | PNY RTX 3060 | PNY RTX 3060 | PNY RTX 3060 |
Case Top Panel | Filter | No Filter | Filter | Filter | No Filter |
Case Front Panel | Filter | No Filter | Filter | Filter | No Filter |
CPU Cooler Fan | Noctua A9x25 | Noctua A9x25 | Noctua A9x25 | Noctua A9x25 | Noctua A9x25 |
Front Case Fan | Scythe Kaze Flex Black | Scythe Kaze Flex Black | Scythe KFB 50% PWM | Arctic P12 | Arctic P12 |
Rear Case Fan | Scythe Kaze Flex Black | Scythe Kaze Flex Black | Scythe KFB 50% PWM | Arctic P12 | Arctic P12 |
Temp Sensor 0 Max | 49 | 48 | 54 | 53 | 53 |
Temp Sensor 1 Max | 46 | 45 | 50 | 48 | 47 |
Temp Sensor 2 CPU Max | 74 | 72 | 79 | 75 | 73 |
Temp Sensor 3 PCI Max | 21 | 21 | 22 | 21 | 21 |
Temp Sensor 4 Max | 46 | 46 | 51 | 48 | 48 |
Temp Sensor 5 Max | 47 | 46 | 52 | 51 | 50 |
CPU Fan Max RPM | 1962 | 1991 | 1997 | 2027 | 2014 |
Front Case Fan Max RPM | 1679 | 1713 | 1002 | 1776 | 1767 |
Rear Case Fan Max RPM | 1679 | 1713 | 1002 | 1776 | 1767 |
CPU Pkg Max Temp | 74 | 72.4 | 79 | 75 | 73.3 |
CPU Pkg Max Wattage | 74.46 | 75.34 | 74.34 | 75.02 | 74.56 |
NVMe Top 970 Evo+ Temp | 52 | 51 | 55 | 53 | 53 |
NVMe Bottom | N/A | N/A | N/A | N/A | N/A |
GPU Max Temp | 74.1 | 72.9 | 76 | 77.5 | 74.5 |
GPU Hot Spot Max Temp | 85.9 | 84.8 | 87.7 | 89.4 | 86.6 |
GPU Max Wattage | 153.51 | 154.16 | 155.49 | 169.53% | 152.98 |
GPU Fan Max RPM | 1838 | 1741 | 1945 | 2041 | 1864 |
