Hey community,
I've been doing some extensive research in the area of SFF PC's. I do have a couple questions though, if the group would be kind enough to chime in. As the title suggests, I'm looking to build a small and quiet gaming build.
Q1. Case selection
From some preliminary research, I came across several options in regards to case:
Q2. Processor
Is the 9600k the ideal choice for gaming? I'll likely not be using this machine as a workhorse for editing. Makes me think something like the 9700k/9900k is overkill.
Q3. Motherboard
Are there any specific considerations I should have when choosing an ITX motherboard for a SFF case?
Q4. GPU
I'll likely go with either a RTX 2070 or 2080. I assume this should be fine provided I get the appropriate water blocks.
Q5. Anything else
Please do feel free to offer any other advice you consider relevant, or perhaps links to builds I can follow.
Thank you for any assistance.
Q1. Case selection
- FormD T1
- Dan A4-SFX
- Louqe Ghost S1
- NCASE M1
Q2. Processor
Q3. Motherboard
Q4. GPU
Q5. Anything else
