Short extension cable
winterbladexx
76
34
Moved my existing build to a new case but my 24-pin cable is a bit short. Is there a way to get really short extension cable for Corsair SF450?
royalba94
AVAENTUM SLEEVING
Apr 2, 2017
268
434
Avaentum.com
I think he's still on a break. I checked his site.
Technically yes but I can do a few small orders like this every now and again, should probably update the notice on the site to say that. :]
Thx for the mention as always! :)
How short are we talking? and would it be a regular extension just really short or more like a small adapter that plugs directly into the PSU?
royalba94
AVAENTUM SLEEVING
Apr 2, 2017
268
434
Avaentum.com
More like around 60-70mm total. I wonder if that's possible.
Depends on if it's just a 1:1 extension or if it's one that plugs directly into the PSU.
I could make an unsleeved 1:1 extension as short as 25mm but for an unsleeved fully modular cable the shortest I can do is between ~35mm-50mm depending on how messy the pinout is. - Those measures are of the length of the visible cables (in between the connectors).
It's possible that I could make the 1:1 extension a little bit shorter but I haven't tried and it gets pretty fiddly to make that short.
winterbladexx
76
34
Yeah, I ordered some custom cables from Cablemod and when I moved my build, the 24pin is short by around 50mm or so. Right now, I'm using the stock PSU cable. Where are based though?
