Hello, I'm putting together a build using Aorus X570i Pro, is-60 CPU cooler and some Ballistix RAM.
I was originally going to use Ballistix Sport LT because I know it fits using these exact components
but now I am tempted to order the newer Ballistix and make it fit.
It's about 1mm taller and about 1mm wider, I expect to run into clearance issues.
Would it be best to sand down the CPU cooler, remove the RAM heatsink completely, or remove the RAM heatsink and sand down one side of the heatsink before reattaching it?
I'm thinking it would be best to leave the RAM alone, it costs twice as much as the cooler and I'm more likely to sell it down the line. this is where I'd have to shave the cooler down.
Thanks!
Thanks!
