CPU SFX PSU Fan Noise
Mopar63
23
Hey gang, I am running a system with the following specs:
  • Rzyen 3600
  • Gigabyte X570 ITX
  • Inland Premium NVME
  • 16 GB Crucial DDR4 3200
  • Sapphire Pulse 5700XT
  • Cooler Master NR200
  • Cooler Master Master Liquid ML280
  • 2x Noctua 120x15 and 2x Cooler Master Sickleflow 120 (both sets at 45% fan speed)
  • FSP Dagger Pro 550
This setup has a power draw, according to my UPS of 360 or so watts under peak gaming loads. I see between 345 and 360 while playing RDR2. After about 10 Minutes of RDR2 I notice the noise from the PC has picked up. At first I thought it was the CPU or GPU coolers but checking, neither was making all that much noise, it was instead the PSU.
I am curious of a couple of things.
  • Is my PSU underpowered to stay quiet, should I get a bigger PSU?
  • Is the PSU fan based purely off of wattage pulled as the various vendor charts indicate or is heat an issue for fan speed?
  • Is it just this PSU, would a different 550 in the same setup be quieter?
smitty2k1
978
500
Yes most, if not all, PSUs have their fan curves tied to power output.
You could try a fan mod or a different PSU. The Corsair gold and platinum PSUs are highly regarded as being the quietest SFX PSUs.
If your case can fit an SFX-L form factor PSU you have some more options, some of those have quieter 120mm fans.
Mopar63
23
The case will fit an SFX-L but the modular cables actually push down on the GPU backplate. I have tried to pull them up enough but just not happening.
I am considing a fan fan with a Noctua 92x14 and also looking at an SF750 or a Silverstone SX-700PT
smitty2k1
978
500
If you're willing to pay the price you can't go wrong with the SF750 platinum.
