Physics is a fair but harsh mistress. For while the heatspreader on your CPU - and the base of your CPU cooler - may look smooth, flat and able to make perfect contact, this is far from the case. Microscopic surface imperfections present on all metallic surfaces work against the movement of energy, by preventing proper contact and thus reducing the efficiency of heat transfer. And while this can be improved with better machining (and in extreme cases, careful lapping of the surfaces), us mere mortals must suffice with the use of thermal paste to bond surfaces together.
Read more here.
Read more here.
