Hello everyone,
I currently own a Node 304, with a Xeon e3 1230 v2, (basically an i7 without igpu and turbo boost to 3.6ghz, cant overclock) 16gb of ram, gtx 670, 1tb 3.5 hd + 120gb 2.5 ssd, and a seasonic 550w gold psu.
I am graduating with a bachelors of engineering in May 2016 (fingers crossed) and I want to upgrade my build a bit by then, as a present to myself. I mostly want to get an i7 that I can overclock, i'm thinking Devil's Canyon 4970k (skylake looks like the same performance but you need more expensive ddr4, but maybe that will change), so I can get pc master race single core performance for those older games that I play, a big one being Vindictus, which only uses one core and is very cpu intensive. I want something quiet and I was thinking of getting a define r5, since it would be big and easy to work with. But as you all know, once you catch the SFF bug there is no going back. I've made 3 SFF builds so far and seeing what new cases are out there and how much I can fit in is so much fun, recently I've discovered Nova, and good god is it beautiful.
Thing is with almost all these SFF builds everyone does a mild overclock or none at all, because of the space constraints. I want to get a 4.6 or 4.7 ghz overclock, or as high as I can get in something of this size, but I'm not sure if it's possible in the smaller cases while staying quiet. I also don't want to go custom water cooling, only AIO if I have to.
If I go with a case like Nova, do you think I could get that kind of overclock with an air or AIO cooler on the CPU? I'm most likely going to stay with one GPU, and with the size of the case I'd have to pick whether I'd go AIO on the GPU or the CPU. If there are other cases where I could achieve a high overclock that are small I'd be open to them as well. The biggest I'd go and what looks like a good choice would be the Silverstone TJ08, or the new TJ08 Pro/PS07-E coming out. Theyre small (ish) and with careful fan and component selection I'm guessing they would be pretty quiet. I also could reuse my existing PSU and RAM, (i'm not rich yet). That would be the safest choice, but ideally I'd like to go as small as possible.
Any help/suggestions would be appreciated.
TDLR; I need MATX or MITX cases that can hold one high end GPU and overclock an i7 to 4.6ghz+ without using a custom loop. The smaller/sexier the better.
