James' build and remarks:
Case: None, $0
PSU: EVGA 400W ATX Power Supply, $26.99
Motherboard: AsRock B85M-ITX Mini ITX LGA1150, $59.99
CPU: Intel Core i3-4160 3.6GHz, $108.99
GPU: MSI Radeon R7 360 2GB, $104.99
Memory: Mushkin Essentials 4GB (1 x 4GB), $15.88
Storage: A-Data Premier SP550 120GB SSD, $37.88
OS: Windows 10 Home OEM, $85.99
TOTAL: $440.71
This build is intended to serve as a solid platform for future upgrades. The use of a Haswell CPU may seem contradictory to that idea, but i5 and i7 Haswell chips should be readily available on the used market for several years, which will allow for an easy drop-in CPU upgrade (and, admittedly, bumping up to the Skylake equivalent pushed the build over the $450 budget). The SSD keeps with the upgradability theme, it’s much easier to just add a hard drive for extra space than it is to switch to a SSD later. Similarly, having a Windows installation off the bat for the best game compatibility is simply a must-have. Including a legit copy and keeping within budget did mean that a few unneeded luxuries like a case weren’t included, however.
Jay's build & remarks:
Case: Logisys CS6801BK, $37.99
PSU: 350w (Included with case), $0
Motherboard: MSI H81l Mini ITX LGA1150, $62.99
CPU: Intel Core i3-4370 3.8GHz, $142.99
GPU: MSI GeForce GTX 750 Ti 2GB, $99.99
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB), $37.88
Wireless: TP-Link TL-WN725N Wi-Fi Adapter, $7.98
OS: Linux ("Your choice"), $0
TOTAL: $437.70
For my build, and unlike everyone else, I went with a truly compact gaming machine. The combo of an i3-4370, a GTX 750Ti, 8GB of RAM, and a SSD is about as good as it ever gets for the low, low price of $450. It even includes a WiFi dongle for casual browsing - a practical feature that makes it a lot easier to use my computer anywhere. Overall, this build would be quiet, small, and capable of 1080p gaming. And it even offers the ability to upgrade to a more powerful Haswell CPU in the future, meaning it's as effective today as it is forward-looking to tomorrow.
John's build & remarks:
Case: Inwin BK623.BH300TB3 Tower, $78.58
PSU: 300w (Included with case), $0
Motherboard: Biostar Hi-Fi A70U3P FM2+, $39.99
CPU: AMD Athlon X4 860K 3.7GHz, $69.99
GPU: PNY GeForce GTX 750 Ti 2GB, $94.99
Memory: Aver Budget Series 8GB (1 x 8GB), $26.99
OS: Windows 10 Home, $99.99
TOTAL: $445.52
My build chose parts that consistently gave me the best bang for the buck. I went with an Athlon X4 860 because it's a true quad-core processor that provides the best performance for the price. I picked a basic motherboard that provided the right features and expandability. I bought 8GB of RAM and a SSD that provides speedy boot and load times. And the factory-overclocked GTX 750Ti is an exceptional value, providing solid performance up to 1080p. All of which is packaged in the Inwin BK623, a remarkably small mATX enclosure that still provides the expandability that gamers value. For the money, and especially for a Windows machine, my rig is cost-optimized and provides the opportunity for future upgrades and expansion.
Josh's build and remarks:
Case: Silverstone Sugo SG13B-Q, $35.99
PSU: EVGA 400W ATX Power Supply, $24.99
Motherboard: AsRock A68M-ITX FM2+, $53.99
CPU: AMD Athlon X4 860K 3.7GHz, $64.99
GPU: Sapphire Radeon R9 380 4GB NITRO, $174.99
Memory: Mushkin ECO2 8GB (1 x 8GB), $24.99
Storage: Hitachi Deskstar 1TB 7200RPM, $41.50
OS: SteamOS $0
TOTAL: $449.43
My machine is meant to take the 'gaming rig' aspect of the challenge to the extreme, and that's borne out with the two decisions that cut costs or provide utility that's specifically useful for gaming: namely, the use of SteamOS, and the use of a mechanical hard drive. Although the former limits the catalog of games that can be played, there's thousands of titles (and growing) available on SteamOS, and "upgrading" to Windows is an easy future purchase that the user can then just transplant their whole library to. Furthermore, although a HDD doesn't give you speedy boot times or app loads, it does provide the storage needed to actually install a bunch games in the first place. Best of all, though, the savings from these choices means that I'm able to install a powerful GPU with enough VRAM to max out titles at 1080p, and play at medium-high settings for 1440p+. I can even have a quad-core processor (quickly becoming mandatory for new titles), 8GB of RAM that's upgradable to 16GB, and reliable part selection that doesn't include unknown brands or a terrible-quality power supply.
James' critiques:
Jay’s build is similarly an Intel build which I applaud. Like Joshua’s build, though, it relies on Linux which is totally unsuitable for a real gaming computer. Maybe one day Linux will be viable, but too many top titles are missing for it to work today. Of course, the real issue with Jay’s build is the ticking time bomb that is the bundled PSU. If actually pushed anywhere close to 350W it is liable to burn your computer to the ground.
John did the right thing by using Windows for the OS, but made the same mistake as Joshua of going with AMD for the CPU. While I wish AMD the best for Zen, FM2 is a dead-end socket and will forever be limited to 4-thread processors. Even if the budget was higher, FX chips aren’t an option since there aren’t any ITX boards for them, so clearly Intel is the correct choice for performance both today and tomorrow.
Jay's critique:
James' build features solid components that are very similar to mine, but his build includes fatal flaws. To start, there is literally no case, and there's only one stick of 4GB DDR3 133Mhz RAM. These strange choices left me scratching my head, and they're simply build killers.
John assembled a decent system, but he chose an AMD Athlon X4, and a single stick of RAM. The cost cutting decision to use older Team Red parts is one that would haunt the user for years to come! It's no way to build a forward-looking machine.
Josh was very excited about his build, and from a graphical horsepower perspective, he has the most powerful rig. But he also has the largest rig - in a SFF contest, mind you - as well as one stick of RAM, a platter drive, and an Athlon X4. This is SmallFormFactor.net. Not LargeUglyBoxFactor.net.
John's critique:
James build is caseless. That's not a build, that's a pile of components. Enough said.
Jay at least has a case, but he's spent more money on his processor than I have, yet gets worse performance in return. His PSU is also questionable - I've actually used the case and PSU that's in my build, and it runs like a champ. And, let's face it, microATX is a better choice for gamers who want to expand their system down the line. Mines is small and provides that flexibility. Oh, and it runs Windows - you know, that operating system where all the games are.
Josh's build isn't any better, for a whole bunch of reasons. He went with microATX too, but his case is larger than mine. His SSD-less build means boot and load times that are laughable in 2016. And again - Linux, really? You can't play Minesweeper on that thing, let alone most real games.
Joshua's critique:
James is crazy if he thinks that a build without a case can even be considered a build. And his computer has only a dual-core CPU, as well as a mere 4GB of RAM, which is hardly enough for three Chrome tabs, let alone a modern game.
Jay's build also has only a dual-core CPU, and the 8GB of RAM is nice until you realize that you can't upgrade it without replacing the whole kit - hardly forward-thinking. And that bundled power supply is such a joke that it's as if he's included a free game with his build: every time you turn it on, there's a 1-in-10 chance that you fry your components! How exciting!
John's build also elects to play the PSU lottery, and his motherboard and memory picks are uninspiring and budget-conscious to the point of leaving me wondering how long they'll actually last. Oh, and his case is ugly as sin, too - I'd take James' case-that-isn't over that 1995-style Inwin anyday.
Most of all, though, all three of them have went with a tiny 120GB SSD that has no room for games, and all three have gone with whimpy GPU's that have only 2GB of VRAM. If you want a true gaming rig, you want performance to match and room to install your games. Only my build has that.
And so there you have it, yearning masses - our four competitors for this month's contest! And what a diverse selection it is... Two builds with Windows, and two without. Two builds with AMD graphics, and two with nVidia. Even the storage and memory vary a lot, in the quest for the best rig and the least-worst compromises.
However, only one of these machines can win! Only one, in the eyes of you, the community, can be chosen as the best $build for this challenge! And to select your choice of victor, all you have to do is navigate to the SFF Forum thread and vote in the poll at the top!
Do so quickly, however, for voting will end in two weeks' time...
Until next month, my dear readers! May your space efficiency be high, and your decibels low!
