S4M tinkerings. Suggestions and recommendations welcome.
R4H8E
28
21
Not quite a buildlog. I'm going to try some ideas I've seen mentioned on this forum.
Build components are here:
PCPartPicker part list / Price breakdown by merchant
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor (Purchased For $160.00)
CPU Cooler: Noctua - NH-L9a-AM4 33.8 CFM CPU Cooler (Purchased For $39.90)
Motherboard: Asus - ROG Strix B450-I Gaming Mini ITX AM4 Motherboard (Purchased For $127.99)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-2666 Memory (Purchased For $144.74)
Storage: HP - EX920 1TB M.2-2280 Solid State Drive (Purchased For $209.00)
Video Card: Zotac - GeForce GTX 1080 8GB Mini Video Card ($469.89 @ Amazon)
Other: HDPLEX 400W HiFi DC-ATX (Purchased For $95.00)
Other: Dell 330-Watt AC Adapter with 6 ft Power Cord (Purchased For $62.00)
Other: Skyreach 4 MINI (Purchased For $224.00)
Total: $1532.52
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2018-09-29 10:45 EDT-0400
Some of the things I'm going to try to do:
- replace the stock l9a fan with a nf-a12x15 pwm. Some dremeling will probably be needed to get it to fit above the I/o (tall wifi shroud).
- replace stock zotac 1080 mini fan shroud with 2x nf-a9x14 pwm fans.
- add a temperature sensor underneath the gpu heatsink so I have full control over fan speed via the motherboard.
- add a plate for usb c over the unused c8 power opening on the case.
This post has changed a few times and I'm unsure if this post should be here or somewhere else. I'm not really doing anything worthy of a build log and the computer is already built, so if there's a better spot for it, I'm fine with it being moved.
R4H8E
28
21
Here is the 120 fan with the chunk taken out:
Had to do that because of wifi pictured below:
