https://videocardz.com/67841/sapphire-radeon-rx-500-series-also-listed-online
Looks like another sff option coming along soon!
Did @Josh | NFC have anything to do with that?
But how much power does it use?
It uses a single 6 pin. The shroud does extend slightly above the PCB.But how much power does it use?
I'm tempted... I was going to go 6gb 1060, but I'm thinking I might just grab the cheapest option that does solid 1080p gaming and then in a couple years pick up an itx sized card with HBM2 as a more long term option. I think both vega and volta will have hbm2 if I'm not mistaken. I'm still a ways off from putting something together though as I ordered my power brick from tabao and it'll take awhile to get here.
Are the dimension listed by Sapphire accurate? The reason I ask is because the width looks about the same as the Gigabyte 1070 mini, but the 570 is apparently 19mm smaller.
