Videocardz is saying that we could be seeing a new entry level GeForce GTX 1630 soon.
NVIDIA preparing GeForce GTX 1630 graphics card, its first GTX x30 model - VideoCardz.com
While this isn't going to be your first choice for running the latest games, it may be suitable for casual gaming, or those just looking for more outputs for a multi-monitor productivity setup.
A GTX 1630 should have better video encode and decode support than the older GT 1030, but it's still unlikely that it will support hardware decode for the newer AV1 codec, which is a pity, as these cards are ideal for compact HTPC builds.
Video Encode and Decode GPU Support Matrix [NEW] | NVIDIA Developer
This is likely to go head to head with AMDs Radeon 6400 and may give another option for those looking for compact half height, single slot graphics cards, and a GPU that doesn't require external power.
I'll probably be sticking with my trusty GT 1030 for a while longer, as I only use it for troubleshooting.
