long time no new case design...
here is my take on a classic layout micro tower case, compatible with ITX sized GPUs and pretty tall CPU coolers
RCC-MIT1 compatibility:
extra large clearance below the motherboard (12mm) to allow for heatsinks on your M.2 drive
more pictures:
I didn't have a normal ITX sized GPU at hand, but a LP GPU also seems to fit fine... a suitable GPU bracket could be e.g. 3D printed...
using adhesive HiFi feet, the case allows for different orientations:
inverted tower with GPU on top
traditional micro tower
or "desktop" mode
For those who like to support me I can offer the RCC-MIT1 build-to-order. For the DIY community I have attached the drawings to this post. Feel free to get the parts laser cut locally and make your own (for personal use only!).
- mITX Motherboard
- PSU: SFX, SFX-L
- GPU: 185 Long x 129 High x 43 Thick (overall max. clearance in mm incl. power cables)
- CPU cooler: up to 124mm
- fan mounting options: 2x 60mm (top), 2x 80mm (back)
- mITX Motherboard
- PSU: SFX, SFX-L
- GPU: 185 Long x 141 High x 43 Thick (overall max. clearance in mm incl. power cables)
- CPU cooler: up to 136mm
- fan mounting options: 2x 80mm (back)
more pictures:
or "desktop" mode
