Hey everyone,
I have long been in the pursuit of my perfect SFF case, since I got into computer building in 2010 and ITX boards started to become more popular and available with 1156 boards.
I have constantly been changing my builds, always searching for the best option I could find and recently, while doing my second DanCase build I sort of settled on something: I'm not going to be happy unless I design the case myself.
So that's what I'm doing, with the help of Michael from Velkase who designs the 4L Velka series cases and takes custom case commissions.
I had some key aspects I needed to cover:
Air cooled with great airflow
Support for 130mm CPU coolers
Support for 225mm GPU's
Clean, industrial design
I have seen similar designed made by other people like sylphz and D_McG's mini-Spartan, but none of these ever really reached a conclusion or were cases that would be made available to the public.
But they sort helped flesh out my final concept and what I wanted from my final case.
I'm about a month away from have the case made, but in the final stages of the design and in a place currently where I can post the initial renders of the case and go through the build.
So, without further ado, I give you Redux:
Component wise the system will be as follows:
i7 9700K
AsRock Z390 Phantom Gaming-ITX
16Gb Team T-Force XTreem 36000Mhz DDR4
Gigabyte RTX 2060 OC
ADATA XPG SX8200 Pro 500Gb M.2 SSD
Thermalright Silver Arrow 130 with Noctua NF-F12
Silverstone Nightjar 450W Passive SFX-L PSU
2 x 140mm and 2 x 80mm Noctua Redux case fans
The case is designed to support 240mm radiators if you use a 17cm GPU, but I want to air cool everything for a simplistic and industrial final build.
It's not going to have any RGB, No IO with only a power switch hidden on the back of the case, nothing crazy. Functional, effective and stylish.
I'm eager to hear your thoughts and impressions!
Big thanks to Michael from Velkase for his patience and amazing talent to help make this a reality, and for allowing me to post his renders online!
Cheers,
Tazpr
i7 9700K
Cheers,
Tazpr
