OPHION
M-ITX CASE
TEMPERED GLASS
- Compace size M-ITX case with max. compatibility
- Supports Max. 330 mm VGA card
- 370x150x218mm
- Supports ATX PSU installed
- C-Type x1 + USB 3.0 x3
- 2 slots
- Top cooling supports 120mm fan x2
The other case is basically identical, except a bit taller and supports a radiator.
OPHION EVO
M-ITX Case (Tempered Glass)
- Compact size M-ITX with max. compatibility
- Supports max. 330mm vga card
- 370x150x288mm
- C-type x1 + USB3.0 x1
- 2slots
- top cooling supports 240mm radiator
- bottom cooling: 120mm fan x1
My biggest concern with these is all the tempered glass - it basically looks like a wider Dan Case with additional spacing dedicated to the CPU cooler, but that won't matter if it can't breathe.
I'm curious what the total CPU clearance is - based on dimensions and comparing it to the A4-SFX I'm guessing ~80mm? Any chance we can get confirmation, or if there would be room for a 2.5 slot GPU?
Additional pictures found from reddits sffpc sub.
