Discussion Radiators: [280] vs [280 + 120] - is it worth it?
LucyMorn
43
I am building an SFF custom loop (Lian Li Q58) and have room for 120 rad at the bottom.
It complicates things - a lot - so I wonder if it is worth it.
The loop will include a 12700k and an undervolted 3080.
The things is - if I put a rad at the bottom, the air that will be pushed into the case, the same air that will eventually go through the 280 rad, will be hotter, so by doing that I will reduce the cooling capabilities of the 280 rad.
I couldn't find any comparison of that, only 240vs360, 280vs360 and such.
What do you guys think?
Teletubby89
79
56
280 will be very tight 240/120 will be enough , i am getting super temps out of that case with hotter hardware.
