Power Supply Quiet Flex ATX PSU 300-500 Watt
MrKnuell
I am searching an testing PSUs and cases since 5 months, in that time I bought about ten different PSUs SFX or Flex or TFX. In production we use Seasonic only.
Everything beside Seasonic it tested was somehow crap or very loud. I found out to avoind TFX or Flex, but now I need a very silent Flex ATX PSU with about 350 Watt bigger dosent matter price also. I know there is geekstore, but I want to avoid midified units because of legal issues.
So hwat I tested in Flex so far was Siverstone FX 350-G which is vry loud, it seams the even use ballbearing.
I am pretty sure that I have a Seasonic PSU in one of our Server which is also loud and on thei page they write that all habe double ball bearing fans: https://seasonic.com/sub The SUB has at least a ZeroFan mode, what I gues that does not help very long since its 300 Watt only anyway.
EDIT: Found Problems with on/off spinning up fan: https://smallformfactor.net/forum/threads/seasonic-ssp-300sub-300w-flex-atx-modular-psu.3308/
https://seasonic.com/sug
Same goes with FSP https://www.fsplifestyle.com/PROP197003673/ also double ball bearing, they say its low like 20dB but thta fully depends on the frequency and kind of singal.
Enhance say nothing about the Fans http://www.enhanceusa.com/upload/DM/201309280858101.pdf which means LOUD
Then I found some other OEM like Shuttle and Inter-Tech etc.
But there must be something?
I know FLex has a bad formfactor with 40mm only, bute at least Noctua Fans are ok, even with 3000rpm.
Any ideas?
chyll2
431
362
Enhance enp 7660b. Seem to be the only silent since it runs cool in mainstream setup since it is a 600w platinum
MrKnuell
Thanx alot! I searched along time but cannot find any details on like Fan RPM / Energy chart.
I found a guy here but until no no realy report anyway.
Does anyone have better sources?
I just asked the manufacturer direcly and probably will order one via Aliexpress in china.
