Hello all! This is my first post here and I'm excited to talk with you! From all the projects that I've seen come from here, I can tell that you all are probably the one of the most intuitive communities out there.
I'm currently trying to downsize my server. To be honest, E-ATX is HUGE and I really don't want to deal with it taking up room in my living room. So, I've settled on an x99E-ITX server inside of a GEEEK a30. The reason that I've chosen x99 is because of the price/performance of the used Xeons from the 2011-3/E5-V3 line.
I want to go diskless, have for a while now, and with 1TB m.2 SSDs and nvme drives I can actually do it. But, given that there is only one PCI 3.0 x16 slot, there is a problem. Xeons don't tend to have integrated graphics. Which means that I would have to run a GPU in that slot. This is a problem because I want to pick up a PCI card to run more m.2s.
So, I started looking into something I first saw here, Bifurcation. I first saw it when someone was running a Galax Katana and a El Gato inside a Saber Sentry. Pretty cool concept and to be honest, when I build stuff, I go out of my way to either try or learn something new. So I thought I'd try it.
I've turned this into a game of numbers. The x99 v3 Xeons have 40 PCI lanes, (so no problem there), a PCIe 3.0 x16 obviously has 16 lanes, and from what I've heard nvme and m.2 drives only take up x4 lanes.
1. Bifurcation seems to be a bit... shady. Not in the "I'm out there to take your money" sort of way but more in the way that I can't seem to find much, if any, information about it. During my searches I've found that Asrock supports it and my motherboard also seems to be able to do it. But I haven't been able to find any documentation on it.
Does anyone know of anywhere to go to find out more about this? Perhaps even know about a video tutorial?
2. Does anyone know where to buy a decent bifurcation riser? Most PCI risers that I find through searching are either sold out or they're mining risers.
3. Power consumption is somewhat a concern for me, will bifurcation split the 75w power from the original pci slot to 37.5w for the bifurcated slots?
4. Some x16 m.2 raid cards claim to support bifurcation. Though, I'm assuming that a bifurcated PCI port will act like any other normal interface for a device. I've found a chart that suggests that for at least this card, and this card, that the m.2 drives are being read as separate devices by the PCI slot itself. A lot of the "cheaper" m.2 and nvme expansion slots rely on a SATA connection in order to get the data out.
Does anyone know of a good nvme expansion cards? I'm looking for something that can support at least 2 nvme OR m.2 SSDs. (Bifurcated x16 will leave 1x8 lane for a GPU and 1x8 lane for a m.2/nvme and they use x4 lanes for a normal transfer rate) I was hoping to not need a SATA cable, but if it needs it, I'll use one.
Anyways, sorry about the word vomit. This has actually been quite the satisfying project and I've learned a lot in the past few days because of it. I look forward to hearing from you all! Feel free to message any suggestions you may have!
What I want to do is create a raid array of about 2 m.2 or nvme drives and use bifurcation in order to also run a single-slot GPU for a display. But I have a few questions. 1. Bifurcation seems to be a bit... shady. Not in the "I'm out there to take your money" sort of way but more in the way that I can't seem to find much, if any, information about it. During my searches I've found that Asrock supports it and my motherboard also seems to be able to do it. But I haven't been able to find any documentation on it.
