I know that the 2.1 ATX spec requires standoffs be at least 6.4mm and fit in a 10mm x 10mm area, however I'm curious as to the standard length(s) which standoff manufacturers tend to follow, and what the length measurement measures from (is it from inside surface of case/frame to back of motherboard, or outside surface or to front of motherboard?)
EDIT: Just a little other thing, please put any dimensions in millimetres, I work in metric, not imperial.
