I know I'm supposed to be adding to this as the build progresses, but things came up since project conception so I couldn't really document the entire process. Now that the build is complete, I'll attempt to work backwards because I know this is something a lot of you have considered.
The goal of this project was to fit the https://www.powercolor.com/product?id=1565842787 into the skyreach mini. It's the perfect width as it'll fit in the case and allow for an hdplex 400 ac-dc to mount underneath allowing for a brick less build. The only problem is it's too long (16mm too long), so part of this project involves machining a custom front bezel shroud to cover this extra length
The other aspect of the build is to deshroud the Rx 5700xt replace the stock 92mm fans with noctua 92mms and make a custom shroud to hold it together
