Project: 2425
Discussion in 'Concepts and Ideations' started by Thehack, Feb 24, 2019.
  1. Thehack
    Thehack Shrink Way Wielder
    Thread Starter Bronze Supporter Creator
    #1 Thehack, Feb 24, 2019
    Project 2425 (24-to-5) is a special 24 dc-atx board designed to reduce your wiring needs to just 5 pins.
    It will be designed for compatibility with sfx PSU.
    As always, miniaturize at your own risk.
    fabio and smitty2k1 like this.
  2. smitty2k1
    smitty2k1 Master of Cramming
    Nice tease!
    Thehack likes this.
  3. Windfall
    Windfall SFF Guru
    GET ON DA HYPE TRAIN!
    XD
    Thehack likes this.
  4. rook
    rook Trash Compacter
    RemindMe! 406 years
    CC Ricers, dealda, NateDawg72 and 2 others like this.
  5. chyll2
    chyll2 Cable-Tie Ninja
    2.4L?? hype
  6. Zackmd1
    Zackmd1 Airflow Optimizer
    24 pin version 2.5 maybe?
  7. fabio
    fabio King of Cable Management
  8. Windfall
    Windfall SFF Guru
    I wonder if this thing will be orange or if it will be green.
    XD
  9. Thehack
  10. Windfall
    Windfall SFF Guru
    hmm.
    Modular?
  11. Thehack
    Always a possibility.
    fabio and Windfall like this.
  12. Phuncz
    Phuncz Lord of the Boards
    Moderator SFF Purist Gold Supporter
    You reduced the 24-pin connector to 5 pins ? Interesting.
  13. Windfall
    Windfall SFF Guru
    Remember that Power connector rant @confusis (pings him yet again lol)?
    He came up with an alternate standard.
    Is this something like that?
    confusis likes this.
  14. Zackmd1
    5 volt
    Windfall likes this.
  15. Hexagone_6
    Hexagone_6 Caliper Novice
    that's a great idea, i've always wondered if we can get rid of those horrible 24pin connector.
    i know that there's a lot of wire for power purpose, but is it possible to maybe get them smaller?
    i mean, this connector is designed for both 300w psu and 1200w psu system.
    how much current draw can a nice itx motherboard draw? from that we might solder some wire....
  16. Thehack
    Nowadays the main power comes through the cpu connector, and not the 24 pin one.
  17. dfrgu
    dfrgu Efficiency Noob
    Just curious, what are the five pins you are going to use? Server boards have done this before and they are able to do it with only four pins: 5VStby, power on, power good, and ground signal. Would it possible to use only these four pins on retail motherboards as well?
    Phuncz and cleveland like this.
  18. Thehack
    Add 12v to it and you got it. A working prototype is on the way but unfortunately I'll be out of town for 3 weeks so it'll be some time.
    Phuncz, Windfall, dfrgu and 2 others like this.
