NOTE: This is a press release. It presented exactly as the company released it with no editing by SFF.N. In this instance, Noctua’ s wording is unchanged and presented as Noctua wrote it. The photos and videos are in the same place they were in the Noctua Press Release where possible. All photo credit is Noctua’s. While we at SFF.N try avoid using direct press releases for our news coverage, there are instances when doing so is necessary due to time constraints.
Noctua releases offset mounting for improved cooling performance on AMD AM5 processors
Vienna, June 13th 2023 – Noctua today announced the availability of its new offset mounting bars for installing Noctua CPU coolers on AMD AM5 processors. By offsetting the heatsink 7mm towards the south side of the socket, more pressure is applied right above the CPU’s CCD(s). This improved contact exactly at the processor’s hotspot can significantly reduce CPU temperatures with typical improvements in the range of 1-3°C.
“We have...
Continue reading...
