NOTE: This is a press release. It presented exactly as the company released it with no editing by SFF.N. While we at SFF.N try avoid using direct press releases for our news coverage, there are instances when doing so is necessary due to time constraints.
Noctua presents NA-FH1 eight channel PWM fan hub
Vienna, May 9th 2023 – Noctua today presented its new NA-FH1 fan hub. The NA-FH1 is a high-quality, smartly-protected 8 channel PWM fan hub that allows up to eight PWM fans to be run and controlled simultaneously via a single PWM motherboard fan header or stand-alone controllers such as the optional NA-FC1. Supporting both 12V and 5V fans with 4-pin PWM and 3-pin connectors, the NA-FH1 is highly flexible and suitable both for PC environments and other 12V- or 5V-based applications.
“While there is no shortage of fan hubs on the market, we found most of them lacking both from a functional and from a safety perspective,” explains Roland Mossig (Noctua CEO). “PWM control and...
Continue reading...
7,732
“...we found most of them lacking both from a functional and from a safety perspective,” explains Roland Mossig (Noctua CEO). “PWM control and RPM readout can be unreliable, ...“
It's a glorified fan splitter, it doesn't really add functionality aside from the OCP/SCP. Also, RPM readout will still only be reliable for one fan!
Anywho,
I'd also have liked it to have a cover on it - doesn't really scream high quality with the PCB showin!
Reactions: Revenant
